| Time for new tyre levers! | |
| Tweet Topic Started: Nov 11 2014, 10:15 PM (566 Views) | |
| mspenz | Nov 11 2014, 10:15 PM Post #1 |
What would you recommend? I have a lovely new rubber ring Distanzia waiting in the shed and have decided to stop being so lazy (& save a tenner) and fit it myself, something I haven't done for years as I have always had big bikes with tubeless tyres and it was easier to get someone else to do the swearing! 3 x 18" levers off Fleabay? I used to do it for all my bikes but somehow just got out of the routine. And my next question is, do I use WD40 or KY jelly Damn, should have posted this in chat, can I move it? Edited by mspenz, Nov 11 2014, 10:18 PM.
| 06' 644. 150 main jet, 27.5 pilots, needle @ 2nd rich, air screws @ 3 turns out, K&N with airbox lid....on and unknown unrestricted end can. Now goes like sh1t ! | |
| hursty46 | Nov 12 2014, 06:50 AM Post #2 |
Moved for you buddy! Tyre levers the bigger the better also get some rim protectors and I find washing up liquid good enough a rubber hammer for breaking bead does help too I am always changing the trials bike tyres myself 😀 |
| Rob 110 | Nov 12 2014, 11:09 AM Post #3 |
for DIY you will nip your rims, unless you use protectors. Garden hose slit down its length is good levers, i use 2 of these. its all in the bend/crank at the ends that help ease the tyre on/off. I dont like the straight ones. http://www.ebay.co.uk/itm/Michelin-type-Tyre-Lever-350mm-motocross-evo-enduro-/251379262117?pt=LH_DefaultDomain_3&hash=item3a875f22a5 and 2 of these as they have a narrower tip for getting under the bead http://www.ebay.co.uk/itm/APICO-MICHELIN-TYPE-TYRE-LEVER-15-Motocross-Trials-Enduro-Motorcycles-Bikes-/331337836945?pt=UK_Motorcycle_Parts&hash=item4d25462991 to break the bead use a garden spade or you can get a cheap tyre changer rig £40 (but they do bend on mousses) http://www.ebay.co.uk/itm/Mechanics-Workshop-Garage-Motorcycle-Tyre-Bead-Breaker-Motorbike-Tyre-Changer-/400800672615?pt=LH_DefaultDomain_3&hash=item5d5194eb67 i made my own tyre rig from an old 15" car wheel :) watch some youtube vids or get a friend to show you Edited by Rob 110, Nov 12 2014, 11:10 AM.
| jonny h | Nov 12 2014, 01:41 PM Post #4 |
get the levers Rob mentioned, not the cheap shit off ebay that will slip and cause you no end of swearing!! |
| Tramp | Nov 12 2014, 01:51 PM Post #5 |
2 buzzetti levers for me ..10 inch ones and wd40 as fairy liquid contains salt...a mx valve puller for tubed tyres and a roll of gaffer tape to add over the rim tape saves them nipples piercing the tube..ohh ahh.... A big G clamp works as a bead breaker and a rubber mallet to help persuade the bugger .. |
| mspenz | Nov 12 2014, 08:02 PM Post #6 |
Thank's guys, think that I'll order 3 of those 15" bars as I already have a basic 300mm bar that I can use as an assist. Used to own an IT250 & a XT550 and thought nothing about changing tyres, unfortunately that was over 30 years ago...ouch Mike. |
| richr | Nov 12 2014, 10:14 PM Post #7 |
Ive always used good old hand soap, not the wife's best Pears stuff though they get funny about things like that Get it into a lather, ohh err and away you go, doesn't attack the rubber either
2:36 PM Jul 11
