Filter
Topic Started: Nov 4 2014, 01:05 PM (355 Views)
phil ten
My 644DS has quite a dirty/oily foam filter (its the one from the haines site that says "Twinair" on it)
am i right in thinking i can wash it out with warm soapy water, then rinse with cold and let drip dry? i've only had K&N before, never this type.
Also, on the haines site there are two types of oil filters. take it there is no reported problems with the cheaper one? do peeps change the filter every 2nd oil change?
Red baron
Hey Phil,
Yes, wash it out as you mentioned then leave to drip dry then soak in it air filter oil (motocross guys usually have some) [the easy way is pour some filter oil into a plastic bag, put the filter in and get the filter saturated, let the excess drip off then fit the bugger, will be sticky so latex gloves are a must]
Personally i change the oil filter every time. Warp9 racing sell a stainless re-useable filter, it's on the procycle usa website under dr650
644 DS, great bike, crap rider
phil ten
ok thanks. is it a case of Wash and oil every service, or do you keep re-oiling when it dries out?
Tar
just re-oil when its dirty and needs a clean. its not a once a month thing.
road use just do it when its visually dirty, or when you do a service
offroad, every few rides depending on mud/dust conditions
boring how to vid http://www.youtube.com/watch?v=MkAZ1LuQkdk
