| rotax timing belt info | |
| Tweet Topic Started: Oct 31 2014, 07:49 PM (1,077 Views) | |
| 604 kev | Oct 31 2014, 07:49 PM Post #1 |
ride it like you stole it
Can anyone help ? I've noticed the post about timing belt problems on the rotax. My bike has only 3.600 miles on it which is genuine .but it sat around for the last 4 years that i've owed it .with me starting it once a month. is the belt going to need changing as i know that some belts have a certain life span. |
| stevenfuture | Oct 31 2014, 08:59 PM Post #2 |
If I was you I would, its not very difficult & once done you know its done. I think Sportax had some if you check you could get a good one wack ot on & bingo you have started fresh. |
| 604 kev | Oct 31 2014, 09:23 PM Post #3 |
Cheer's mate. I fault it would be best .I move back to Ireland Jan \ Feb and will give the bike a full overhaul before going back on the road it not worth doing it in Spain it cost a fortune in postage I need a full set of plastics and tyres and a few other bits should be a god project so will be pestering you guys for bits and advice lol |
| Sportax Racing | Nov 2 2014, 10:41 AM Post #4 |
Hi Kev, Dayco recommends changing the belts every 20,000km or 2 years which ever occurs first. For those that race, id recommend every 12 months. Hope that helps.. |
| 604 kev | Nov 2 2014, 11:07 AM Post #5 |
Thanks for your help guys .give you a call when i move to ireland |
