Fork seals
Topic Started: Oct 26 2014, 09:54 PM (320 Views)
blue boy 644
Evening all,
would any of you kind chaps know the part number for the fork seal kit from All Balls (dust & oil seals) 2003 644 DS. Just when you think you have finshed all the jobs another one raises it head :what:
Cheers.
slide the dust seal down carefully with a screwdriver
spray brake cleaner up round the oil seal
get a piece of acetate/35mm film/laminated paper or other thin plastic
slide it carefully up between the seal and chrome
work your way round and it will clean the muck out, use more brake cleaner
may solve it (usually does)
or you may need new seals :D
I have used these before, all ok
http://www.ebay.co.uk/itm/Pyramid-Parts-Fork-Oil-Seals-Dust-Seals-for-CCM-644-R-30-04-07-/290911713427?pt=UK_Motorcycle_Parts_13&hash=item43bbb07893
blue boy 644
Thank's for your help lads,i have ordered a set from Haines & Co so now all i have to do is get the bloody things apart :what: plus the adjuster on the top of the right hand fork leg is stuck and won't turn so that will need sorting to. The list just keeps growing :arms:
blue boy 644
Quick update for future reference the part no for the ALLBALLS fork seal kit for the 644 is 56-126. dust + oil seals.
