Dellorto Carb 604; Guide for Dellorto Carb
Topic Started: Oct 16 2014, 09:19 AM (7,335 Views)
RotaxMatt
Hi Guys,
Found this this morning, I've read on here that the Carb fitted to my 604e was fitted to their bikes like early KTM's etc.
Found this site:
http://www.advrider.com/forums/showthread.php?t=635497
Is it the same carb?
Thought it might be useful as it gives KTM part numbers for Dellorto parts .........
M
he hasnt removed the idle jet fully, this would only matter if you are changing the size though. after you take out the little top jet, there is a tube under it that has to come out, this however is a real arse to get to, and very easy to break.
RotaxMatt
Oct 16 2014, 03:15 PM
Hi Jonny, will this affect me when overhauling the carburettor?
I can see what you mean by looking at his photos, you can't see that tube you mentioned can you ha
Will be sure to look out for it when I take the carb apart..
M
with regards to that tube, i would say do not even try and touch it, they are known for breaking the screw head. you have no need to do anything inless up or down jetting the idle jet.
just have your carb ultra sonic cleaned :)
