| little help | |
| Tweet Topic Started: Sep 21 2014, 10:34 PM (1,306 Views) | |
| ccm6442002 | Sep 21 2014, 10:34 PM Post #1 |
just bought my ccm 644 duel sport with super Moto wheel and love it but just relisted that it needs a new chain and sprockets was just told that its a DR650 engine so would a DR's chain and sprockets fit also the fork seals are leaking anyone no where I can get them cheap (seals and dust covers) iv cheeked eBay cant seem to find any think |
| Roadster604 | Sep 22 2014, 07:26 PM Post #2 |
Have a look at Haines and co for the lot |
| keep the faith | |
| whitebuck | Sep 22 2014, 07:30 PM Post #3 |
Give Haines your money.......as the only independent retailer left we need Anthony and his little shop needs us |
| Walshy | Sep 22 2014, 07:35 PM Post #4 |
As others have said, anthonys a great guy and always goes that extra mile. http://www.hainesmc.co.uk/ |
| stevo604 | Sep 22 2014, 08:12 PM Post #5 |
a+1 as well very good service
| ccm6442002 | Sep 23 2014, 11:40 AM Post #6 |
cool beans thanks the only thing is they do chains and sprockets on there own not as a kit so does the DR650 chains and sprockets fit and its £30 for the lot so a lot cheaper and every little helps lol |
| sdysonR30 | Sep 23 2014, 12:15 PM Post #7 |
Id say no as the hub will probably be different. |
| ccm6442002 | Sep 23 2014, 12:27 PM Post #8 |
what the standard teeth on front and back sprocket and what length chain |
| sdysonR30 | Sep 23 2014, 01:09 PM Post #9 |
16-43 maybe?? wouldnt take my word for that tho, i run 14-46 talon sprockets with a 118 link d.i.d chain at the moment, but i think the ds swinger is a different length than the r30? some one on here will know for definite |
| jonny h | Sep 23 2014, 03:02 PM Post #10 |
pretty sure the DR runs a 520 chain, your 644 runs a 525 , £30 for a kit would mean shit sprockets and shit chain to be honest. standard sprockets for SM wheels is 15/43 , ring Talon and ask them for a kit as the do RK chains too which are pretty decent. with the DS swing arm you "should" be looking at 118 links. |
| ccm6442002 | Sep 26 2014, 12:32 PM Post #11 |
anyone no what head gap I need in my forks as im doing the fork seals on the weeks end |
| Monty | Sep 26 2014, 03:18 PM Post #12 |
I set my air gap at 120mm, fill the forks up, then pump the fork to fill the valve, once the air stops bleeding to the surface, set the air gap, I use a tube attached to a syringe, the tube is clamped to the fork top and ends 120mm inside the fork, remove excess oil with the syringe, when it sucks air you have the correct level. use 5w oil, if you want the forks stiffer try 100mm air gap. |
| ccm6442002 | Sep 28 2014, 07:16 PM Post #13 |
Do you no how much oil per leg |
| Monty | Sep 28 2014, 07:37 PM Post #14 |
no, as it depends on whether the forks are stripped and cleaned and all oil removed, or its just tipped out and replaced. usually just over 500ml so you still have to buy 2 ltrs |
| ccm6442002 | Oct 12 2014, 02:35 PM Post #15 |
has anyone got after market lever on there bike if so where and how much if they fit from another bike what make model and year thanks |
| Monty | Oct 12 2014, 05:06 PM Post #16 |
think an aprilla clutch lever fits, tho what model I don't know, try using the search button as its been talked about before |
