R30 fuel line routing
Topic Started: Sep 17 2014, 07:41 AM (307 Views)
Breedsey
Hi, does anyone have a picture of how the 2 fuel lines are routed with the twin petcock R3o tank?
I've just got one to fit on my 644DS (so i can paint it)
an exploded diagram or a photo would be good?
Edited by Breedsey, Sep 17 2014, 07:41 AM.
Martin0000000
I've got a twin tap tank for my r30 and looking at images it looks like the hose from the left hand tap goes over the carbs and tee into the other hose well that's what I'm going to try
Breedsey
Thats pretty much what i did, anyone have tips for what order to open the taps up? I'm thinking right side onto reserve for normal running then when it runs out, left side onto reserve?
R30Paul
If you zoom in on this pick it will give you a good idea on the fuel line routing...
http://www.dirtbikerider.us/CFFileServlet/_cf_image/_cfimg-7384837375431037273.jpg
As for the taps - both ON - or when the bike starts stuttering - both to RES - as the fuel is in the wings either side of the frame - hence the use of the twin taps...
