| Rotax clutch adjustment | |
| Tweet Topic Started: Aug 22 2014, 07:21 PM (1,524 Views) | |
| Monty | Aug 22 2014, 07:21 PM Post #1 |
Slacken the cable at the clutch, undo the centre plug on the clutch casing, slim 13mm socket to undo the nut, adjust the screw in the middle till it just bottoms out, then back of 1/8 of a turn, hold screw and tighten lock nut, replace plug, and adjust at clutch lever. Then clutch lever has an adjustable span, yours may be set for a short pull, to adjust, push lever away from bars and turn the knob to a different number, if on 1 try 4, it may give you more pull. |
