fork oil, how much /what level
Topic Started: Mar 11 2014, 02:55 PM (1,054 Views)
nelly t5
hi guys
ive just replaced the fork seals on my 2002 r30 644
now im ready to add the oil
so ive read various posts on here,but im struggling to make sense
and i want to be sure that im reading about the correct forks
so a couple of questions for you guys please
1, how much oil do i put in? or how do i measure the air gap correctly?
2, which grade do i use , ive bought 15 but i believe now it should be 10 ?
thanks guys
ian6pot
The anount/air gap and grade of oil is more to do with personal preference and you weight rather than there being a correct setting.
you could find 100mm air gap and 15w oil is good for you but not for me if you see what i mean
Edited by ian6pot, Mar 11 2014, 03:48 PM.
nelly t5
thanks buddy
well
im a fat arsed 15st
i like a hardish set up if possible but i aint got a clue how much oil to add
is there a ball park figure to start with , i can always add more,
but dont want to start with too much and blow the new seals
sorry for all the dumb ass questions
std air gap is 120mm, road riding 15w should be fine, 5-10w for the offroader
nelly t5
doh
sorry i dint see the 2nd line at all
nelly t5
thanks guys
now for another dumb question
how do i measure the air gap exactly?
can this be done with the forks on the bike with the wheel just of the ground
or on the bench vertical?
on the bench, spring removed, pump the Staunton/top tube up and down to fill the reservoir, top tube fully down then measure the air gap, I fill more than needed, then use a syringe with a pipe attached, marked at 120mm and drop inside, keep syphoning till you pull air,
pull top tube out refit spring and top, screw together
nelly t5
brilliant thanks buddy
thats just how i like it, easy steps
cheers
nelly t5
all done and back together
thanks again for your help guys
its much appreciated
nel
Mar 11 2014, 04:13 PM
or get an old bathroom/kitchen cleaner spray bottle thing
ditch the bottle and cut the straw of the spray trigger to 120mm or whatever
fill the oil roughly and then squirt the excess out
nelly t5
right then
sorry for bein dumb AGAIN
i did the forks as above ,but they feel really soft
to get the 120mm air gap i could only get 280ml in each leg
i did pump the inner rod up and down to fill the reservoir thing
now i know ive done something wrong but WHAT ??
thanks guys
You did leave the spring out? You should get almost 500ml in
nelly t5
well i think i may have been a bit too hasty ,not letting the oil settle before measuring the level
took the forks off again and repeated and i managed to get 460ml in this time
thanks guys
oh yes , i did reove the spring btw
« Previous Topic · Welcome · Next Topic »
