| need your help guys already | |
| Tweet Topic Started: Mar 9 2014, 01:10 PM (303 Views) | |
| nelly t5 | Mar 9 2014, 01:10 PM Post #1 |
hi guys newbie nel here ive already introduced myself on a previous post but now i need your help i need to replace the fork seals on newly aquired r30 644 ive got them off, got both ends off each leg,drained the oil,removed the circlip so i can now see straight through the empty leg, now what? should they pull apart with a stern pull apart or am i missing something? done a few fork seals in the past including usd,s but i just want to be sure thanks guys |
| ian6pot | Mar 9 2014, 01:16 PM Post #2 |
Yes, top off,bottom off,drain,pull out damper and spring setup,remove circlip,........then yank the apart, do doubt will need a couple of good pulls. |
| nelly t5 | Mar 9 2014, 01:56 PM Post #3 |
thankyou buddy doh i dint see the circlip under the dust seal doh the circlip i did remove was the outer one so glad i dint tug on em too hard ah well you live and learn hey thanks again for the prompt reply |
8:56 AM Jul 11
