| Newb R30; New member R30 | |
| Tweet Topic Started: Jan 30 2014, 02:47 PM (433 Views) | |
| sgraham666 | Jan 30 2014, 02:47 PM Post #1 |
Hello I just joined the forum. I have an R30 2004. It stopped working this morning and it had blown a 30 amp main fuse in the starter relay I also noticed that I once had a spark on the key when I took it out the ignition! I am after a wiring diagram to check things over, has anyone had problems with the wiring? on the right of the frame thee is a main loom that looks like it could easily rub against the frame anyone had issues there before? Cheers sgraham666 |
| hursty46 | Jan 30 2014, 04:41 PM Post #2 |
Hello n welcome to the site wiring on Ccm is a bit crap just check near the rear sub frame that's were mine rubbed through the joys of owning a Ccm :P |
| stevo604 | Jan 31 2014, 12:18 PM Post #3 |
welcome to the forum. .put it in the tec section and you will get more talk on it ;)
| ian6pot | Feb 1 2014, 01:17 PM Post #4 |
Hello :huh: |
| Davie | Feb 2 2014, 12:17 PM Post #5 |
Welcome mate...hope you get it sorted
Illegitimus non tatum carborundum | |
| Dodger | Jun 16 2014, 09:40 AM Post #6 |
Hello.. |
