404 tech info & part numbers: alternative parts, bearing/seal sizes, etc.
Topic Started: Dec 22 2013, 12:07 PM (7,755 Views)
DonkeyBike
DonkeyBiker
I was thinking about putting together the manufacturers part numbers for every part used on the 404, plastics, electrics, switches, bearings, seals, wheels, suspension etc. It might take ages though, very handy to have. It would be useful if someone else did the same with the other models of CCM and had a list of alternative sources and part numbers for the CCM parts.
WHEELS
CCM404DS Bearing & Seal sizes
Rear hub BEARING: 2x 6004-2RS required & 1x 6204-2RS
Front hub BEARING - 2x 6004-2RS required
Seals: Front: 2off: 24x42x8 Rear: 1off 25x47x7 & 1off 24x42x8
Front Brake Pad: EBC FA181-TT
Rear Brake Pad: EBC FA208
For CCM 404 E / DS
ENGINE
Output Shaft Seal: 30 X 40 X 6 09283-30053
Gear Lever Seal:
Clutch shaft Seal: 10 X 20 X 6.
Clutch shaft Bearing: 12 X 16 X 10.
FCR Carb: 13200-29F10 superseded by 13200-29FF0
BODY PARTS
Replacement saddle: '96- 01 yz 250.
Front Mudguard: KTM Part No: 590.01093100
Rear Mudguard: Yamaha YZ 125-250__'96-'02 (needs cutting where it joins onto the CDI tray).
Rad. Shrouds: Honda CRF 450__'03
RHS Panel: Yamaha YZ 125-250__'96-'02
LHS Panel: Yamaha YZ 125-250__'96-'02 (left side panel needs some trimming).
Fork guards are KTM WP fork type.
FRAME & SUSPENSION
Chain guide: KX85
Chain slipper: cr125
Front forks are WP MXMA 4860 and rear suspension is WP PDS 5018
Fork Seals: Be careful here, not as straight forward as you might think, I'd suggest
removing old ones to confirm...
Needle Bearings for Shock: ??
Front Sprocket: Suzuki DRZ400: Jt sprockets JTF432SC
Rear Sprocket: Same as CCM644 on spoked wheels or Husqvarna: JT sprockets JTR822 / JTA822
Steering Head Bearing: AS109 = L45449
404 foot pegs are same as 2001 Suzuki RM250
Switch Gear: GasGas EC (afaik)
ELECTRICAL
Spark Plug: NGK CR8EK or CR8E or CR8EIX (the suffix "IX" represents Iridium)
Battery: YT7B - BS
Warning, contrary to suggestions the YTX12A-BS is physically too big to fit in the battery holder.
Edited by DonkeyBike, May 30 2018, 08:45 PM.
CCM404DS@AdvIrl.com
DonkeyBike
DonkeyBiker
I intend adding to the first post until it's as complete and accurate as possible, if you have any information to add or correct the above please reply and I'll modify the first post.
This second post will contain specs/dimensions specific to the CCM404:
"TopEnd of engine..."
The cylinder head bolts get tightened to 18 foot pounds (25 N-M, 2.5 kgf-m) first in an X pattern, then tighten again to 33.5 foot pounds (46 N-M, 4.6 kgf-m). The bolts and nuts on the outside of the head get torqued to 7 foot pounds (10 N-M, 1.0 kgf-m). The cylinder head side bolt, if you removed it, gets tightened to 10 foot pounds (14 N-M, 1.4 kgf-m). The camshaft journal holder bolts get tightened to 7 foot pounds (10 N-M, 1.0 kgf-m). And finally, the valve cover gets 7 foot pounds initially, then 10 the second time around.
Valve clearance is;
Intake: 0.10~0.20mm (0.0039~0.0079 in)
Exhaust: 0.20~0.30mm (0.0079~0.0118 in)
http://dwulet.com/bikes/docs/Torque_DRZ400S.PDF
Edited by DonkeyBike, Feb 10 2014, 01:09 AM.
CCM404DS@AdvIrl.com
stevo604
you have hit the nail on the head their.it would be handy for the 404 604 and the 644 and made as a sticky for parts references as a whole lot of people would be asking what fit this and that.good speek :worthy:
DonkeyBike
DonkeyBiker
Front and Rear brake pad part numbers added to the first post. 😎
Edited by DonkeyBike, Nov 2 2015, 04:33 PM.
CCM404DS@AdvIrl.com
kito
Can anyone confirm what rear sprocket fits the 404 ? I just ordered a dr350s rear sprocket and the bolting circle is 10mm to small. I'm not interested in the aluminium sprockets as I already have a talon on and want to replace it
kito
Jun 8 2016, 11:26 AM
same as the 644, as same wheels
kito
Can the moderators please correct the list so others don't buy the DR350s sprocket that does NOT fit. I ordered a JT sprocket JTR822-47
JTR822-48 ect does fit.
Thanks kito
Done.
Dunno how that Dr350 shit got on there.
DonkeyBike
DonkeyBiker
Jun 9 2016, 07:43 PM
Done.
I put that "SHIT" there Rob, I've ordered, received and fitted a rear sprocket for the DR350S three or four times now and they are the
same part, it must however be the DR350S.
The ebay link below lists the JT 48T Rear Sprocket 520 for Suzuki DR350S 1990-1993 as part number JTR822-48 as described by Kito
http://www.ebay.ie/itm/JT-48T-Rear-Sprocket-520-for-Suzuki-DR350S-1990-1993-/321903815619
If I'm mistaken let me know.....
Daithi.
Edited by DonkeyBike, Aug 27 2016, 10:54 AM.
CCM404DS@AdvIrl.com
Angustoyou
The 404Ds battery is NOT as listed above, that one is physically too large for the holder. The correct battery is YT7B - BS
DonkeyBike
DonkeyBiker
Angustoyou
Jan 29 2017, 06:12 PM
Thanks Angus, first post corrected... :bye:
CCM404DS@AdvIrl.com
Walshy
Front brake and clutch levers? I'm gonna buy some fancy ones but don't want to go universal. Any ideas guys?
Front is pre 2003 ktm. Can't remember clutch
Walshy
Cheers rob maybe someone else will post the clutch :dirtbike:
jamie96
i know this is an old thread but do replacement clutch levers come with the two plastic shims ?
Walshy
Mine didn't mate
rwxalas
Kernow
Kernow
Any idea what silencers fit , the oval scorpion would be ok if I could find one , mine still has the heavy round one fitted.
Sickswan
So does anyone have the needle roller bearing sizes for the swing arm to add to this?
404 ALTERNATIVE SWINGARM BEARINGS/BUSHES:
Replace the ccm journals with 2 more oilite bushes, one flanged and one plain, gives a total width of 34mm as opposed to width of journal at 38mm. Still enough bearing surface imho
unfortunately theres no oilite bush with a 14mm ID and 30mm OD, so its bushes within bushes :rolleyes:
I know i have replaced a hardened journal with oilite phos-bronze, but gotta be better than 2mm play ;D
here's what i've ordered (google will pick a supplier for you ;) ):
AM1420-14 Oilite Plain Bush 14x20x14mm - Pack Size: Pack 2 4.68
AL1420-20 Oilite Flanged Bush 14x20x20mm - Pack Size: Pack 2 4.82 +vat and 1.50 p&p
loads cheaper than CCM journals.
so in summary looking at the pic http://www.sparesccm.com/images/404SwingArm.jpg
items 12 and 25 replaced with: AM2026-30 Oilite Plain Bush 20x26x30mm Pack of 2
item 14 replaced with: AM1420-14 Oilite Plain Bush 14x20x14mm - Pack 2
& AL1420-20 Oilite Flanged Bush 14x20x20mm - Pack 2
all fitted today, no play wahey :w00t:
just had to put a file on the inside of the bushes to help the spindle in :bigthumb:
just to add i had to do this every 18months or so on my heavily offroaded/raced 404
sprocket side always wore first
think its the constant suspension movement from offroad that increased wear
My R30 on road has only had one set in +10,000miles
Go to Next Page
