| rotax exhaust gaskets | |
| Tweet Topic Started: Apr 19 2013, 08:02 PM (407 Views) | |
| ccmcraig | Apr 19 2013, 08:02 PM Post #1 |
got some exhaust gaskets from Apophis as they were cheap and i was buying other stuff. i dont think my rotax current has any fitted amd i cant find any pictures, should they be fitted? Craig |
| crazy jester | Apr 19 2013, 09:19 PM Post #2 |
I was looking at them too but mine doest have them either. Ive got 604 rotax. |
| Cuz | Apr 25 2013, 11:44 AM Post #3 |
The ccm doesn't have any guys |
| Mad Cow | Apr 25 2013, 09:48 PM Post #4 |
They will be Armstrong/Can Am/Bombardier MT500/MT350 ones, almost exactly the same cylinder head, so they fit perfectly. Just pop them in the head and bolt the exhaust stub in against them. I fitted them because my pipes were so loose in the head, I had a bad exhaust leak that caused really loud (and constant) backfires everytime I rolled off the throttle. And the leaking hot gasses were melting my front mudguard. A dab of silicone is helpful to hold them in place, or you could just use silicone instead of the gaskets. I used some to seal the exhaust into the stubs too. Only finished the bike off tonight and took it out for a quick spin and it didn't backfire once! |
Tony (aka Mad Cow) http://madcowracing.blogspot.com
| ccmcraig | Apr 28 2013, 07:29 PM Post #5 |
Thanks guys Reckon i will fit them, guess it cant do any harm! |
| ccmcraig | May 30 2013, 08:42 PM Post #6 |
mmmmmmmmmm they appear to be too small. the exhausts stubs wont slide inside of the gaskets, or are they supposed to be the same diameter as the stubs? |
| BK350 | May 30 2013, 09:28 PM Post #7 |
Hi Craig, should be the same diameter as the stubs. I fitted gaskets as on my old MZ Rotax, outside diameter is 32mm, inner 27mm. Chris Edited by BK350, May 30 2013, 09:29 PM.
8:44 AM Jul 11
