| distanzia pressures | |
| Tweet Topic Started: Apr 11 2013, 05:03 PM (269 Views) | |
| aka1974 | Apr 11 2013, 05:03 PM Post #1 |
hi all just bought some avon distanzias to put on me ccm r30 to try em out on some mild green lanes and gravel roads what kind of happy medium would you recommend for pressures considering i iwill be using on a mix off roads cheers paul |
| Rob 110 | Apr 11 2013, 07:13 PM Post #2 |
28psi rear 24psi front i run these on whatever tyres the R30 has, on and off road, all year to make a big difference offroad, you'd need to be sub 20psi and then need rimlocks (but they wouldn't be wide enough anyway) running low pressures would allow more tyre compression (and pinch flats against rim) on rocks, especially as they are lower profile walls and less plys than MX/enduro tyres hth |
| aka1974 | Apr 11 2013, 07:22 PM Post #3 |
ok cheers mate i been running 26 28 with diablos on so will try this when i swapover |
7:13 PM Jul 11
