644 now 10 years old
Topic Started: Apr 10 2013, 04:02 PM (296 Views)
Pa644
... and is back in the workshop. Voltage regulator is b*ggered and I canŽt get a new one that fits from Sukiyaky as the connections are different. Suppose IŽll need to get someone clever to help me out. Thought at first it was the lithium ion battery but that and the alternator are ok.
Aged 644
After 10 years what bits are left on the bike that ain't vibrated off lol
Any 5 wire reg should do the job, you need a 200w or larger,
so long as it mounts in same place should not be a problem, if bigger or smaller a adapter plate can be made to mount it.
The 3 yellow wires are from the alternator and dont matter which was round they go, the other 2 do, as one is +ve and other -ve.
The block can be removed and crimp lugs fitted in their place.
I'm using my last spare, otherwise you could have it Pat.
eblag no 271181389469 or 110944896102 if they wont send to Germany let me know and I'll buy it and send
Edited by Monty, Apr 10 2013, 05:33 PM.
