thread lock
Topic Started: Apr 7 2013, 07:09 PM (520 Views)
thumb
going to be doing some work on bike shortly , what thread lock for nuts- bolts etc would you guys recommend and also sealent for cambelt cover
Thread lock I stealborrow permanently from work, clear silicon is what I use for lower cam cover and back plate.
any clear silicon will do I'm sure
whitebuck
Silicone !!!! ..... bloody obvious as soon as you said ...... thanks Monty
I use the stuff to seal up all plug connectors with, never thought of using it on a bolt
I use Wynns gasket maker but I'd be on the pound shop bathroom sealant if I hadn't been given big tube of it. The manual states Loctite 221 low strength for casing bolts but I've used whatever's to hand on external stuff and nowts ever dropped off or been to tough to remove easily
for thread lock i use Loctite 248, its a stick. i get mine from halfruds.
380323837897
thumb
Apr 7 2013, 07:21 PM
right first job in the morning is off to the stores to do some STOCK TAKING me thinks , loads of sealents in there lol :angel:
Remember in the old days using that hideous gasket sealant that was a proper t*@t to clean off and didn't work very well. Came in orange or red, can't remember the brand name but it was rancid
spaceman1969
The best sealant is threebond 1194 it's what the manufacturers use never goes hard and oil and petrol proof ;-)
thumb
Apr 7 2013, 08:49 PM
I sure do, you'd spend forever scraping the old gasket off a casing and get a nice bead of blue/ red gasket sealent all the way round only for it to feckin slide off soon as you lifted the casing up to put back on. Or lookin down oil filler and seein red/blue snot flyin round with the oil
Edited by thumb, Apr 8 2013, 04:45 PM.
spaceman1969
Apr 8 2013, 03:47 AM
nor does well seal Posted Image used for sealing the camshaft box on rover k16 engines and also on landrover TD5 engines amongst other engines . designed by rolls royce . sticky as fook and messy if you spill it ;)
thumb
:worthy: thanks for the info guys, got the cambelt and the O rings are in the post, might tackle it at weekend but might have my new toy by then :P more updates on that to follow
koban
Is loctite 348 suitable for all engine bolts,in my engine manual it says loctite 648/221.
The 648's for things like your cambelt wheel to stop 'em spinning. They have 574 as the only other loctite in the manual for the head o rings.
koban
How did you get on with your head cuz.
All bike stuffi's on temporary hold Koban. Got injured and not worked for a while so cash has suddenly become tight. Sold the standard engine out of the main stead to pay the rent so I have no running bike at the moment. Typical isn't it,the suns been out ever since. I went into work today so if I feel ok in the morning I can hopefully get back on it pretty quickly.
I've got the alloy plate to make the mik adapter,but haven't been able to file. The barrels the first thing to get money thrown at it. Currently on with that selling bits and bob's that I don't need to fund lol. I'm still toying with what to do with the head. I'm still looking at the possibility and cost of altering the rocker oil feed on the 560 head,which is already ported.
Anyway one way or another it needs to be finished before the end of this month.
koban
Made my adaptor plate, want to put it back together but just can't find the time. Shoulder pain is horrible hope your on the mend mate.
