Finally got a lock up garage!
Topic Started: Apr 2 2013, 06:54 PM (1,133 Views)
pickle3
Been waiting a year but now got a tenancy for a lock-up, buzzing can now finish my bike and get it back on road, without walking 2miles to mates garage just rwnd corner so can work at ow :drinks: n leisure now so no excuse to put the last few hours to get it road worthy
http://i864.photobucket.com/albums/ab205/p...13/SAM_0759.jpg
good times mate, just make sure its nice and secure
pickle3
Iye yeah cheers m8 still buzzing, thinking of trying to find another biker to garage share cut dpwn on rent. Theres a smashed up plug on wall connected to a light outside, gonna check if it live, if not gonna be posting a wanted ad for a generator. Or wait for aldi to get some more in.
thumb
Get the walls painted up with some cheap matt white emulsion , this will help brighten up a dark space if you've only got one light. The matt paint absorbs the light making it brighter, where as with silk and gloss finnish the light bounces off the walls and is lost.
The workshops at my works get painted every year or so with matt paint and I the question why matt paint ? - answer see above
if you cant fit a ground anchor , fill a dust bin with concrete and a chain hanging out of it and that way they will have a concrete ball to carry when they try to steal your bike lol
pickle3
Might just do that with paint got a big tub of that crap emulsion that takes about 8 coats to get a covering, may still have a tin of garage floor paint if it not crustified with age :). Most concerned with it being a single ply tin roof the possibility of condensation although there's plenty of airation. Anyone know of any deals on padlocks?
is it an up and over garage door lee?
i fitted one of these to the bottom corner on each side of the door
that way they would have to get through them before they got the door up . had two mountain bikes stolen as the thieves wrenched the bottom of the door up even though there was pins at the middle of the door to stop the door opening . nearly 4 grands of bikes taken
mind you i had a concrete drive way to my lock up so the hasp part on the door with a half inch plate at the rear so the bolts did not pull out if crow bar'd . the bit the lock goes through into the concrete . and two abus disc locks Posted Image
i then made an anchor from a machine lifting eye and inch thick plate and bolted to the wall with counter sunk raw bolts with hex heads with a ball bearing hammered into the hex head . the anchor is still in my old lock up as i could not get it off lol
bike was locked with a chain and this u lock Posted Image
16mm shackle .
when i took the bike out i used a chain then one of these Posted Image ok it was heavy but thats why the DS has a rear rack ;)
pickle3
Some good pointers there, was thinking of useing a bit of box section cut diagonal putting holes on longest plane, drilling some holes in concrete with bit opening plugs, but bet I end up getting lazy with chaining & shackles up.
It is Wood double door, needs a lick of paint for starters, and wasnt planning on going ott security conscious but getting paranoid now thought a brass padlock will do so know previous owner hasn't got access through key copies
Best jobs to move in Lee :D
pickle3
Haha, I know might get a hammock an turn it into a :drool: mancave for doghouse days
thumb
we use the abus disc locks all over the hospital sites good quality. you can buy them in 2s keyed alike- same key for both locks. also use CISA locks on the workshop roller shutters, can't get in with croppers or cut with saw.
thumb
pickle3
Apr 4 2013, 06:35 AM
most of them gennies that aldi/lidl do are only about 750w/850w -
average elec drill 500w/ 750w - kettle 1kw so nowt left to run anything else + 2 stroke - smoke the feckin place out
pickle3
Apr 7 2013, 09:13 PM
the more locks and obstacles in the way the longer it take for them to steal it. how far from a house is the lock up? you could wire a simple alarm to the door . a key switch Posted Image a bike horn Posted Image plunger switch Posted Image and a 12v car battery and you have a simple alarm
just remember to switch it off when YOU open the door
thumb
replace the bike horn with one of these - 190680746974 12v piezo sound bomb 104 db @1m £4.99. My bike shed is wired into house alarm+ this in shed will makes ya ears bleed :drool:
Edited by thumb, Apr 8 2013, 06:25 PM.
thumb
Apr 8 2013, 06:24 PM
if he has 240v power this would be better http://www.alarmworld.co.uk/intruder/bellboxes-sounders/master-blaster/prod_72.html
127db . its one cupid stunt would recomend and he was an alarm fitter if i remember right
Whitey r30
Ive have a bnQ £20 alarm for 3 years made by yale ,With a key fob takes Bats Does the job great and very loud ;)
thumb
this is one of things that i like about this site f you ask a question or ask for help, you might not get the exact answer, but you'll get a pointer in the right direction :arms:
