| Valve clearances - do I need the tool??? | |
| Tweet Topic Started: Mar 28 2013, 03:31 PM (350 Views) | |
| Hoggyf | Mar 28 2013, 03:31 PM Post #1 |
Chaps Do i need the suzuki special tool to set my valve clearances and if so what is it thats so special, will i have anything else in my tool box that will do. |
| jonny h | Mar 28 2013, 03:42 PM Post #2 |
you dont "need" the tool .. but my god it makes the job alot easier and quicker. its a square drive, thats the only thing special about it, why they had to make it square and not a normal hex bolt i dont know .. but they did. the tool costs about £2.50 i think |
| bighit | Mar 28 2013, 06:17 PM Post #3 |
as jonny said. get the tool . a clock winder may even fit if you get the right size . i tried doing mine with a adjustable spanner(small one) and then tried needle nose pliers . then i got the tool from robinsons suzuki dealers and it was a million times easier |
| Rob 110 | Mar 28 2013, 09:06 PM Post #4 |
i have a small 4" King Dick but works a treat ;) its an old '50s job, proper engineered adjustable with no play brilliant |
7:14 PM Jul 11
