FFS it happend
Topic Started: Mar 19 2013, 11:11 AM (545 Views)
Whitey r30
:what: FFS it happend guess what ?????? side stand bolt snapped bike fell over lucky it fell on my fence no damage the top bolt of the 2 has snapped clean off inside the frame bit ,Ive been trying to Drill it out :what: :chin: any tips its not going well
I was all kitted up for a ride then bang :chin: bolt snapped bike fell CRY :o
Edited by Whitey r30, Mar 19 2013, 11:12 AM.
whitebuck
Lucky the fence was there ..... could have been a lot worse :blink:
Ride It Like It's Your Ex G/F
Whitey r30
Telling me whitebuck i was scared to look ^_^
Stands off just chipping away drilling the bolt out at the moment going to get it extended this week about 80mm im going for take some of the weight off the bolts ;)
Dont forget to fit High tensile ones
Whitey r30
Thats what the problem was i think monty the one that snapped was just a normal steel bolt
I now have fitted the HT bolts they have a golden colour to them does this sound about right ??
steve53
I really think the best thing for these stands is to memove them bloody things are a night mear i took mine off and lean it up against something when im out can be a pain but it least it stays standing...hope you bike aint got to much damage pal.
i may have a look at removing the whole thing, re-weld another bikes sidestand and bracket. mines on the lean again with the stronger bolts too :S
Edited by rossonza, Mar 19 2013, 08:21 PM.
Munkee
It's a total PITA to sort, b depending on the size of bolt I've had decent luck previously by drilling the middle of the bolt then jamming a slightly larger flat blade screwdriver in (use an old one!) then turning the bolt out.
Failing that, the correct way is to use ne of these:
Bolt extractor
You drill the bolt and insert the remover, which is effectively a tapered left hand threaded tap. Once it reached the point where the hole is too small for the tapered thread, the bolt 'should' start to wind out instead (probably worth using lots of penetrating fluid on there first)
Steve
Edited by Munkee, Mar 19 2013, 09:05 PM.
Munkee
Mar 19 2013, 09:01 PM
Bolt extractor
Steve
and what happens when you snap the bolt extractor in the bolt ? mmmmmm you wont drill that out unless you have expensive drill bits ;) see it all the time at work. drill or bolt extractor snapped in the bolt and we then have to either spark errode it or scrap the part altogether . if you come into our place with a snapped glow plug in the head and you have snapped a bolt extractor in the glow plug we will tell you head is scrap unless we get it out same if you snap a spark plug in say a ford focus head due to water in the plug recess . if you then try a torque bit hammered in or a bolt extractor you actually spread the plug out jamming it in the threads .
if you must use bolt extractors use straight fluted ones rather than the left hand thread ones above as when you tighten the above ones in they spread the bolt out and jam it
if you can get a punch into the hole and give it a good belt it may loosen the threads enough to drill it and as the drill bit bites it will screw it out as the drill bites . or try left hand drill bits
thumb
I've seen 2 of them extractors snap i don't trust them. I snapped one of the pinch bolts that hold front spindle managed to drill pretty much centre of the bit that was left almost all the way through and it spun out. plenty of wd 40 and a bit of heat if you can get in helps
Whitey r30
Its out after 2 hours of drilling swearing and crying 2.5 drill bit then kept going to bigger size snapped about 10 what a fuck up :rant:
As bighit said i had some decent bits the cheaper ones just burnt it
Thanks all above :drinks:
Whitey r30
Mar 20 2013, 06:59 AM
what i did was get a better strength bolt (12.9 grade i think they are) and get them just a little longer so you can get a nut on the back of them . they dont come loose then .
just keep and eye on them as the bracket acts like a guillotine and cuts them very easy when they are loose
12.9 bolts are the strongest grade you get i think . 8.8 is ok for non stressed use .10.9 is better than 8.8 .
Free Forums with no limits on posts or members.
Learn More · Sign-up Now
