drivetrain noise
Topic Started: Mar 18 2013, 09:22 PM (255 Views)
sounds like chain is rubbing on something metal, Is this the top chain slider? i think its warn down onto the bolt heads.
http://www.hainesmc.co.uk/ccm_motorcycle_spares/ccm_644_spares/ccm_644_service_items/
Ross
mine did this, its the reason i run a 16t front sprocket, if it has worn down i know monty did a home replace job on the runner
Mine did this n it was the chain n wheel wasn't level
hmm good idea Jonny.... maybe i will change, but its going to need replacing regardless for the sake of £15 i dont mind fitting a new one.
ordered, fingers crossed the heads of the screws havnt been worn flat..
