What disk is this?
Topic Started: Mar 16 2013, 09:23 PM (328 Views)
Any ideas guys? also, does anyone want it? After a r30 644 rear
thumb
if i remember rightly ccm wern't the only ones to use the 3 spoke wheel. The marking above the 2nd bolt to the right might be NG like the one my front 320mm which i think is spanish made. might be wrong.
Thats overlapping my current disk, Im sure it said NG Esapana on it. Ill check later
thumb
Mar 16 2013, 10:08 PM
got my glasses on now can see the original disc below ^_^
Anyone? is this a disk for the spoked wheels?
Mar 17 2013, 11:55 AM
I assume its not your photo, ask for dimensions hole pcd, distance between holes, outer dia, inner dia. with this info I can tell you as I have one hanging in garage
Edited by Monty, Mar 17 2013, 01:05 PM.
Monty it is mine. I bought it off a forum member but its strong.
I'll get measurements later
If you have it, surely you can try to fit it or at least remove your spoked wheel and compare........ :o
The thing is I don't have a spoked wheel. The bolt patterns completely different
Can you not fit the whole wheel then, if you have mags?
I'll look at my mag wheel tomorrow
think theres a bit of confusion here.
My bike has mag wheels, i dont have spokes, the above picture was taken when we went to swap the disk over as mine is worn. we then realised it was wrong so photo'd it.
