TPS problem; PI**ED OFF !!!!!!!
Topic Started: Mar 9 2013, 08:47 AM (1,637 Views)
ozz770
Transmogrified Teenager
I went to adjust my "TPS" yesterday, not that my bike was running badly, just curiosity got the better of me to see if it was set up properly or not.
Anyway when I went to undo the sensor, I noticed that one of the shoulders (bolt holes) had cracked & upon removal found it to be snapped completely.
How pi**ed off was I :rant: :rant:
So now im after a replacement TPS sensor, as when I measured the resistance, I found that no matter where I positioned it, the reading was always exactly the same. So in fact it was not actually working at all since I bought the bike :'( :'(
Anybody got a spare lying around, (before I order a new one) ? If you do drop me a PM to discus a deal (sexual favours not included)!!! :P :P
If it aint broke.....Dont fix it !!!!!
seeing as your in the right position can you do me a favour please.
i have heard that if you just disconnect the TPS sensor the bike will still run fine, the ecu will just choose the richest setting (which isnt alot).
could you try this out and tell me your results please?
nigemac
The TPS sensor was removed from my r30 before I got it--- it runs perfectly well without it and the bikes now done 11k :)
nigemac
Mar 9 2013, 02:45 PM
cheers :)
ozz770
Hi jonny h,
Mine runs all ok & I guess its not been working since I got it.
It has always smelt rich when running, once the choke has been turned off after initial cold start.
I have ran it with the TPS disconected & it feels exactly the same. ;)
ozz770
I phoned to find out how much a new TPS was today. Unfortunatley they are out of stock at the moment, they did tell me the OEM part no for it though (13550-13D60) so now I might be able to get one from my local bike shop !!!!!
There was one on Ebay for a GSXR600/750, so I done some homework and found out that quite a few Suzuki engined bikes ran with the same 'TPS' so I might be able to cross-reference one that way, if all else fails :-/
This might help someone else, if you have the same dilema as me.
:dirtbike:
I know the TL 1000 has the same tps unit
Hmmm TL1000 nom nom
here you go
http://www.ebay.co.uk/itm/CCM-644-R30-TPS-Sensor-/251249012925?pt=UK_Motorcycle_Parts&hash=item3a7f9bb0bd
whitebuck
Handy link Monty ..... £20 for the TPS
£5.30 Delivery????? :what:
HTF do they justify that???? :blink:
Ride It Like It's Your Ex G/F
They deliver by hand I think. and the postman fits it for you as well as setting it up :poke:
ozz770
Thanks Monty,
Cheers for the link (eBay). I have just got it, bit pricey on the P&P though, but a lot cheaper than a new one !!!!
Thanks again
ozz770 ;)
doh! didn't spot this thread
think i have one on a spare set of carbs!
pm me if you or anyone needs it in future
ozz770
No worries Rob110, thanks ;)
ozz770
Got the new TPS from eBay this morning, its just stopped raining (3 days solid :what: ) so im off down to the garage to fit, it then if it stays dry out for a quick blast :D
ozz770
Udate of the saga of my TPS problem !!!
Been down to the garage & fitted the replacement TPS I got from eBay.
I put it on & set it in the middle position as per factory fit, put the tester on it, got a reading of 5.41 so I opened the throttle got the same reading 5.41 DOH !!!
Tried it in different positions always with the same reading 5.41, even tried a different meter still the same. :-/ :-/ :-/
So out for a quick blast around the block, felt exactly the same as before.
What the F**ks going on ????
Have I bought a knackered sensor or what ????
To say i'm well pissed off would put it lightly. :'( :'( :'(
Any ideas folks ?
you are testing it correctly,
measure across out side pins to get reading ie on yours 5.41
cable tie throttle wide open,
Then measure across middle pin and right hand pin, obviously with plug removed, you should get a lower reading
ozz770
Happy to say its "all good now", as Monty pointed out I was doing it wrong !!! (the cold got to my brain).
I was not measuring between the middle pin when the throttle was open fully. STOP laughing !! :$
So the TPS from eBay was all ok after all.
Thanks for the assistance, I now know for the future and can return the knowledge with others.
Cheers all.
Glad its sorted Ozz
