Cam timing; How to set
Topic Started: Dec 20 2012, 06:44 AM (506 Views)
Gibbo
Guys
How does one set the cam timing on a 644 ?
Expecting my cam back from Kent any day.
I thangyou.
I see dead people
If you have left the engine at tdc, install the cam with the scribe marks in line with the mating surface of the head, fit sprocket and chain, and push chain tensioner in by hand to make sure all timing marks line up, obviously fit sprocket bolt, then turn engine to fit second bolt..
once happy timing lines all aline tighten bolts and knock tabs over, fit tensioner. set tappets 4 in 8 out
at this stage turn engine over by hand, to make sure timing is correct and valves dont hit the piston.
G1bbo
what if the engine isnt at TDC? (just in case)
if it aint, then make sure it is, or you will be removing the head again to change a pair of valves, and maybe a piston.
small inspection plug top of left casing, facing forward. you will see the timing marks.
Gibbo
Cheers fella.
I see dead people
I think one of you Gibbo's needs to change their name, bloody confusing at times. Aint got a clue which one I'm typing too :poke:
Gibbo
GIBBO = Dad (the one with the talent)
G1BBO = Lad (the one who does daft things :what: )
Edited by Gibbo, Dec 21 2012, 08:28 PM.
I see dead people
OK, the Dad see's dead people
G1bbo
He's a paramedic lol
wR1sty
Not in the west midlands is he? My Bro in-law is a fast response in reditch area.
If your not on the edge, your taking up too much room
Gibbo
No mate. East Mids for me. I also drive FRV.
I see dead people
wR1sty
My hats off to you mate after the run down of his calls this xmas. I dont know how you lot do it, give me Afgan any day ;)
